router's clock for PBX
Aug 13th, 2007
URGENT!
I have a router 2801 who has E1 controller. Through this controller I connect router to PBX (Avaya Tenovis Integral 33. Because the PBX cannot give the router sync clock how can I setup the router to give sync clock the PBX.
paolo bevilacqua Tue, 08/14/2007 - 00:52
  • Hall of Fame,
    Founding Member
"clock source internal" unde controller E1.
Also do not forget the commands networks-clock-participate and network-clock-select.
mljevakovic Tue, 08/14/2007 - 02:19
I've tried but I've got the message: "Controller e1 0/0/0 is not deriving clock from line."
paolo bevilacqua Tue, 08/14/2007 - 03:11
  • Hall of Fame,
    Founding Member
Right, this is the case when controller has clock internal. So leave the "networck-clock" commands as default and you will be sourcing clock to the PBX.
mljevakovic Tue, 08/14/2007 - 03:23
I cannot see the command "network-clock-select 1 E1 0/0/0" in my sh run output and I've still have "slip errors".
paolo bevilacqua Tue, 08/14/2007 - 04:31
  • Hall of Fame,
    Founding Member
That makes me think the PBX is indeed using internal clock.
Try setting clock external and "networck-clock" commands on the router and see how it goes.
mljevakovic Tue, 08/14/2007 - 04:43
I've put clock source line and after that I could put the command network-source-select 1 e1 0/0/0 and also now Ican see it in th sh run output.
paolo bevilacqua Tue, 08/14/2007 - 05:02
  • Hall of Fame,
    Founding Member
Now check for slips and if possible do the same on PBX. The try sending a long fax between router and PBX and if it goes you're all set.
mljevakovic Tue, 08/14/2007 - 05:35
sh network-clok get me
Priority 1
Clock source E1 0/0/0
Clock state GOOD
Clock Type E1
there are no slip errors but it seems that PBX cannot get sync clock from router. :(
Is there any way to check more...
paolo bevilacqua Tue, 08/14/2007 - 06:30
  • Hall of Fame,
    Founding Member
What is the PBX reporting ? When the router is set for internal clock but slips are seen it means the PBX is not resend back router's clock but it's own.
paolo bevilacqua Tue, 08/14/2007 - 07:37
  • Hall of Fame,
    Founding Member
Nothing wrong but nothing is configured under controller E1.
mljevakovic Tue, 08/14/2007 - 07:46
This is config of controller e1Č
framing is CRC4
Line code HDB3
Clock source is line
paolo bevilacqua Tue, 08/14/2007 - 08:02
  • Hall of Fame,
    Founding Member
That is all good but unless you configure pri-group under controller there is no way you can connect voice to the PBX.
mljevakovic Tue, 08/14/2007 - 08:14
How can I do it?
I've put isdn switch-type primary-net5 in global config mode and after that I tried to config pri-group under controller but I ve got message "Insufficient resources to create pri-group -it has been removed"
paolo bevilacqua Tue, 08/14/2007 - 08:17
  • Hall of Fame,
    Founding Member
you need PVDM2 module in the router. If you have less than PVDM2-32 (check show diag), try configuring the pri-group with as many timeslots as the PVDM2 that you have (eg, 8 or 16). Then hopefully the PBX will take starting from the bottom and should work, but you should configure the PBX for a matching number of B-channels as well.
mljevakovic Tue, 08/14/2007 - 08:27
I have 2 DSPs, 32 Voice Resources
but when I put any number of time slot I've get the same message
paolo bevilacqua Tue, 08/14/2007 - 11:39
  • Hall of Fame,
    Founding Member
Please send "show diag" and "show version".
mljevakovic Mon, 08/20/2007 - 05:33
I've solved it. If you want I can send you what I did.
