can I use bulk configuration from icm6.0 to icm7.0 for migration ?
Aug 13th, 2007
Dear all.
I will migrate some customer site.
They used icm6.0 version, but there are a lot of misconfiguration.
So They decided to upgrade with different configuration.
Anyway to reduce time for migration,
I want to use bulk configuration.
But someone told me that it is not possible migration from 6.0 to 7.1 becauseof very different DB Schema.
But it is possible migration from 6.0 to 7.0 because their DB Schema is same.
So Can I use bulk configuration from icm 6.0 to icm 7.0 for migration ?
Thank in advance for kind reply.
lpezj Thu, 08/16/2007 - 00:56
  • Gold, 750 points or more
When you migrate from version 6 to version 7.0 you must use the Database Migration Tool, too.
So, there is no way to use the Bulk Configuration to pass configuration data from version 6 to version 7. The database schemas are quite different.
Hope this helps,
Juan Luis
