syslog via url
Answered Question
Aug 13th, 2007
Is it possible to creat a perl-script which send syslog via url ??
Correct Answer by Joe Clarke about 9 years 5 months ago
You will need to login to the slave, and manually enable the automated action to send your messages. Currently, there is no automated high availability features for LMS.
Overall Rating: 5 (1 ratings)
ycae Mon, 08/13/2007 - 23:48
Why would you like to do that?
As far as i know, syslog deamon only accepts message through port udp/514.
What you could do is having a perl script on both sides, one sending the message to the other one through an url and the one getting the message passing it to syslogd.
Yves
r.kallfass Tue, 08/14/2007 - 00:05
First thanks for answer. I want send syslog only if a certain server is not online, so i need a perl script. Why Url ? Because i have an openview server for syslog, and i can send syslog only through an url.
Joe Clarke Tue, 08/14/2007 - 08:35
If your device is running 12.3(2)T or higher, you can use the Embedded Syslog Manager on the device to send syslog messages in any format you want, and to any destination. ESM uses TCL-based filters to modify syslog messages in-line. This means you can also drop the message or modify its content. More about writing ESM filters can be found at http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00801a8516.html .
r.kallfass Tue, 08/14/2007 - 21:49
Thanks for help, an other question, can i disable/enable automated actions with CLI-commands ?
Joe Clarke Tue, 08/14/2007 - 21:58
If you mean automated actions in RME, no. These can only be enabled and disabled via the GUI.
r.kallfass Tue, 08/14/2007 - 22:09
Yes, i mean automated actions in RME. My Problem is, i have two server(master-slave) which runs with LMS3.0, the master sends syslog to an openview server, but i want, if the master is not there, the slave server should take the renouncement and send syslog to the same openview server. How can i realize that ?
Correct Answer
Joe Clarke Wed, 08/15/2007 - 08:31
