Log
Aug 13th, 2007
access-list branch-policy line 43 permit tcp 172.16.0.0 255.240.0.0 host 172.30.2.140 eq 445
This is my ACL.But i wanted to know which are all systems are connecting to 172.30.2.140.the broblem is if the source systems are connecting always to 172.30.2.140 means i could find trou sh conn command rite, But they are connecting occasionally.hence i m getting hit counts in that particular ACL.So could please share with me, How could i find the Connecting source ip address.Please help me..Thanks in advance
Overall Rating: 4 (1 ratings)
rochopra Tue, 08/14/2007 - 02:17
  • Cisco Employee,
enable syslogging for the traffic and log all the traffic matching that ACL to syslog server.
~Rohit
sureshkum Tue, 08/14/2007 - 02:20
Thanks a lot for ur response.I have added already.But unable to find any entry related to 445 port for that corresponding source and destination.I m getting only denied logs.but it should come under permit log i think so.my syslog trap level is notification.What i have to do further?.Please..Acl in given below
access-list branch-policy line 43 permit tcp 172.16.0.0 255.240.0.0 host 172.30.2.140 eq 445 log 6 interval 300 (hitcnt=106)
sureshkum Wed, 08/15/2007 - 23:38
sorry for delay reply.
No.Its coming through leased line..
Richard Burts Thu, 08/16/2007 - 06:21
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
sureshkumar
from your previous post: my syslog trap level is notification. I believe that the logging level for access lists is informational. Change the trap level to informational and let us know what happens.
Rick
sureshkum Thu, 08/16/2007 - 23:24
hi rick,
thanks a lot..Found the logs..thanks a log
sureshkum Thu, 08/16/2007 - 23:30
Rick i have a query,
Is syslog will generate only deny logs bydefault?..In order to receive all type of(what ever the connections establishing and denied logs also) what are the config setting we have to do in Pix?..
Jon Marshall Fri, 08/17/2007 - 00:41
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi Sureshkumar
I have already answered this question in VPN security forum for you. You need to set your syslog trap level to informational.
If you leave your trap level as notification you will not see the permits.
Jon
sureshkum Fri, 08/17/2007 - 01:26
Sorry jon, that day i thought wrongly that my logging level is informational.Today i justifyed.
i have one more query in above post.kndly reply me
Richard Burts Fri, 08/17/2007 - 02:36
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Sureshkumar
I believe that your question is: Is syslog will generate only deny logs by default?
The answer to that is no it is not default to generate logs only for deny. It will generate logs for any ACL statement that includes the log keyword. So if you have permit statements including the log keyword then you should see the permitted packets in your log messages.
Rick
