ycae Mon, 08/13/2007 - 23:54
what kind of IOS is it? IP base? I think for enabling routing on the 3560 you need at least the advanced ip services but i am not sure.
Yves
skolasssvt Tue, 08/14/2007 - 00:34
My IOS is IPBASE but standard IP routing is implemented in this image. I have configured my network with VLANs, This switch routing comunication between this VLANs.
Jon Marshall Tue, 08/14/2007 - 01:01
As Yves has said IP Base does not support multicast routing. IP Base does support basic inter-vlan routing + RIP but if you want more advanced routing protocol support + multicast then you need the IP Services image.
Jon
