mheusing Tue, 08/14/2007 - 02:43
  • Cisco Employee,
Hi srini,
you might want to check the DIMMs and reseat them. Some pictures how to do this are found at
http://www.cisco.com/en/US/docs/routers/access/1700/1750/hardware/installation/guide/upgrds.html#wp1011746
If the problem remains, you might simply have a defect memory chip and need to replace it. You can follow the procedures described in the document above.
Hope this helps! Please rate all posts.
Regards, Martin
guruprasadr Tue, 08/14/2007 - 03:42
  • Gold, 750 points or more
HI Srini,
Refer link below for general Flash Card Troubleshooting documentation:
http://www.cisco.com/en/US/products/ps5854/prod_troubleshooting_guide09186a00802c35d3.html#wp52302
If the problem continues, you will have to report about the defective Memory Card to the Vendor from whom you purchased the Router.
PLS RATE if HELPS
Best Regards,
Guru Prasad R
