Bad SIP Transfers in CME 4.1
Aug 14th, 2007
Whilst I've been messing about with registering a Grandstream GXP2000 to our CME 4.1 server's SIP service, I've found quite an annoying problem.
The phone registers fine and can make external calls via the SIP trunk absolutely fine. The phone will also accept transfers of internal calls (ephones), <strong>but</strong> if I attempt to transfer an external call form an ephone, to the Granstream - the external call is cut-off. I've isolated the 'debug ccsip messages' output which describes what is happening, but I'm by no means an expert in debugging SIP output.
Aug 14 09:16:49.807: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REFER sip:[email protected]-router:5060 SIP/2.0
Via: SIP/2.0/UDP cme-router:5060;branch=z9hG4bK3432633
From: <sip:[email protected]-router>;tag=2CD733C8-216A
To: "Tom" <sip:[email protected]-router>;tag=as221e2abe
Call-ID: [email protected]-sip-gateway
CSeq: 102 REFER
Max-Forwards: 70
Contact: <sip:[email protected]-router:5060>
User-Agent: Cisco-SIPGateway/IOS-12.x
Timestamp: 1187083009
Refer-To: sip:[email protected][email protected]%3Bto-tag%3Ddb0457357be0d469%3Bfrom-tag%3D2CD77068-25C3
Referred-By: <sip:[email protected]-router>
Content-Length: 0
Aug 14 09:16:49.811: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 202 Accepted
Via: SIP/2.0/UDP cme-router:5060;branch=z9hG4bK3432633;received=cme-router
CSeq: 102 REFER
User-Agent: Asterisk PBX
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
Supported: replaces
Contact: <sip:[email protected]-sip-gateway>
Content-Length: 0
Received:
NOTIFY sip:[email protected]-router:5060 SIP/2.0
Via: SIP/2.0/UDP asterisk-sip-gateway:5060;branch=z9hG4bK49b17aad;rport
From: "Tom" <sip:[email protected]-sip-gateway>;tag=as221e2abe
To: <sip:[email protected]-router>;tag=2CD733C8-216A
CSeq: 104 NOTIFY
Max-Forwards: 70
Event: refer;id=102
Subscription-state: terminated;reason=noresource
Content-Type: message/sipfrag;version=2.0
Supported: replaces
Content-Length: 49
SIP/2.0 481 Call leg/transaction does not exist
Aug 14 09:16:49.815: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Tue, 14 Aug 2007 09:16:49 GMT
CSeq: 104 NOTIFY
Content-Length: 0
Aug 14 09:16:49.843: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:[email protected]-router:5060 SIP/2.0
Via: SIP/2.0/UDP asterisk-sip-gateway:5060;branch=z9hG4bK136ae0fa;rport
CSeq: 105 BYE
Max-Forwards: 70
Content-Length: 0
Where 'cme-router' is the router on which CME 4.1 is installed and running, and 'asterisk-sip-gateway' is our SIP gateway (which the CME 4.1 SIP-UA connects to) that handles more advanced call routing features.
If anyone has any ideas - I'd appreciate the help! It's not a massive problem, but I'm keen to see this one through. I should be able to upgrade to CME 4.2 at some point this week, so we'll have to see if that helps matters.
Paolo Bevilacqua Tue, 08/14/2007 - 03:15
Hi, not sure it that is you case, but try:
voice service voip
no supplementary-service sip moved-temporarily
Let us know if it works...
firebadger Tue, 08/14/2007 - 06:26
Hi, unfortunately that hasn't helped :(
My voice service voip config is as below:
voice service voip
allow-connections sip to sip
sip
registrar server expires max 240 min 60
no call service stop
And the Grandstream phone config is:
voice register dn 1
number 2007
allow watch
refer target dial-peer
mwi
voice register pool 1
id mac 000B.820D.0536
number 1 dn 1
template 1
dtmf-relay rtp-nte
voice-class codec 1
description Grandstream
The voice class is g711alaw, followed by g711ulaw.
I'm not sure what the 'refer target dial-peer' does :/
I'm now running CME 4.2, with 12.4(11)XW2.
Paolo Bevilacqua Tue, 08/14/2007 - 06:44
the thing is that cisco doesn't officially support third-party SIP phones for CME so when something doesn't work you're on your own.
Good luck!
firebadger Fri, 08/17/2007 - 02:18
Well, maybe someone who isn't so Cisco-centric may wish to help in this instance :)
I can't be the only person with these troubles, considering SIP is /meant/ to be a standard.
jasondu88 Thu, 12/06/2007 - 19:42
Hi, can someone help on this. I am having the same issue. A SIP phone can transfer to a skinny phone, but a skinny phone cannot transfer a call to a sip phone. however skinny phone can call directly no problem.
The IOS I am using is 12.4(15)T1.
gsidhu Sun, 12/18/2011 - 05:30
I have come across similar issue Cisco 8961 (SIP phone) fails to transfer an external caller to a Cisco SCCP phone; I get the following message:
subscription-state terminated reason noresource
Does anybody know what the fix is?
