setting up PIX515E VPN for two networks
Aug 14th, 2007
We have a PIX515E and I want to set it up so it can serve client VPN connections for a network on the inside interface and also for a network on the dmz interface.
On a client machine we set up the ip address of the PIX in a VPN connection and the user can log on using credentials and domain. Now the PIX has to look up credentials using RADIUS, but some users are known on domain A (inside interface) and some users are known on domain B (dmz interface). Domain B is completely different and uses other internal ip addresses, dns servers, ip pool etc.
Already I have set up VPN for the inside interface and that was easy and it works ok.
But can I create such a configuration? We only have one DSL line and we want both networks (domain A 192.168.1.x and domain B 192.168.10.x) to go through this PIX.
Your help is more than appreciated!
Frank
