Different Gateways on Vlans?
Aug 14th, 2007
I need to add a new SSID/VLAN to my existing access points. These already have 2 SSID/VLANs on them and are working fine.
My problem is that for the new SSID/VLAN I need to use 802.1x authentication and for that to work the Access Point needs to talk to a Radius server, which is not on the Access Points Subnet. The Access point will need to talk to the Gateway on the new SSID/VLAN, which is different to the existing Gateway, used for the existing SSID/VLANs on the Access Point.
Is there any way of adding a new Gateway (IP address?) for the new Vlan, like you can with a switch?
Cheers,
Jen.
ivillegas Mon, 08/20/2007 - 09:11
  • Silver, 250 points or more
All you have to do is create sub-interfaces on the router and create VLANs on the switch and the APs. Then you can do 802.1x for the SSID with the RADIUS server on a different subnet.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
