Cisco 4503 Supervisor II Plus
Aug 14th, 2007
I have a Cisco 4503 Switch with Supervisor engine II plus, and i need to configure OSPF routing on it and it doesn't support. How can i overcome this issue?
Edison Ortiz Tue, 08/14/2007 - 06:04
It's a hardware limitation, you need to have Sup IV or later.
If budget is an issue, I recommend getting a router (1800 would do) to run the routing protocol and let the switch handle the layer2 tasks.
