Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1927379members
1240059discussions
Community Activity
Hide Finesse Gadget Header/title
Hi, I'm trying to hide the "Supervisor Assist Gadget" title for the Finesse 3rd party gadget. In the gadget xml, I removed the title by which I was able to hide the gadget title and the text moved up to where the title is but now I'm getting empty s...
1d3999d0-d301-4988-a26f-3105aff6f980.jpg bbc85726-c204-47e4-8f3b-629c64062a5e.jpg
SakethN by Level 1
  • 102 Views
  • 1 replies
CS-DESKPRO-K9++ USB Control
Can I use a RS232/serial to USB converter to control the Cisco CS-DESKPRO with Crestron control? The Cisco Deskpro doesnt come with an RS232/serial port. Controlling to Ethernet is not an option for the project i am working on.
jvputian by Level 1
  • 18 Views
  • 0 replies
IPv6 ping not working when pinging other LAN
I configured the simple network below to test the connectivity of the ipv6 in the devices. The configurations are as shown and ipv6 unicast-routing is enabled. When pinging from Router 5 to Router 6 G0/1, it succeeds but when pinging from Router 5 to...
abandoned call to agent timer
We have many calls consider as abandoned due to caller hang-up, how I can make the calls consider abandoned if ring on agent more than 10sec, and if the calls ring on agent less than 10sec not consider as abandoned, because many calls hang-up after r...
matee by Level 1
  • 146 Views
  • 3 replies
Wireless IOSxe Client Ioslation and multicast
Hey everyone,Questions - on a guest WLAN I have client isolation enabled via the Peer to Peer blocking action to drop.  I can see it blocks peer to peer unicast traffic, however multicast traffic between peers still flows.  I can limit the mdns messa...
Alex-Pr by Level 1
  • 90 Views
  • 2 replies
uccx - CUIC 12.5.1 - Repors: Chart with abandoned call total
Hello world,I am working on creating a custom report based on the stock reports available for our call center. We would like to total the abandoned call  for each day, sorted by the hour of the day. I cannot seem to create a report that only shows th...
MyaDime by Level 1
  • 94 Views
  • 3 replies
ISE 3.2 Repeat Count Details
Hi,on ISE 2.4 in the live logs pages the report that one got clicking on the repeat counter was very useful because the endpoints were sorted by repeat counters. So it was very easy to find the endpoints with high repeated counters.With ISE 3.2 the r...
Providing value to the parameter in yaml through CLI
Hi Team, This is the format of my yaml file: testbed:    name:    servers:    password:    custom:        version: "10.3.4" Instead of providing the value to the version manually in the yaml, I want to provide this value with the CLI I am using for e...
o1 by Cisco Employee
  • 36 Views
  • 0 replies
Resolved! How to disable mac address in 9800 WLC
Hi Guys, As we know, there is option in Cisco 5520 WLC to mannualy disable any Mac addresses of user to deny network access to him. Is there any disable mac address option in Cisco 9800 WLC?
Noovi by Level 1
  • 1578 Views
  • 6 replies
