CSS 11503 - Hostname
Aug 14th, 2007
This may be very simple question, but make me confused. How to change hostname,
example: from CSS11503 (default) to may be like CSS-LB-01 because i must implement 4 CSS 11503.
Anybody can help me ?
Rgds,
Jerri
Syed Iftekhar Ahmed Tue, 08/14/2007 - 10:29
I think you are looking to change the CSS prompt
You can use following command to set it
prompt
To make it permanent do a save_profile.
Syed
giordano234 Tue, 08/14/2007 - 20:19
hi Syed,
change with command 'prompt' can not see in running-configuration, correct?
i mean like router/switch we can see hostname in running-configuration..
before i'm try change with host name ip_address but no impact, still CSS11503.
Jerri
kurtdeneef Tue, 09/02/2008 - 00:15
I have the same problem.
When people connect (through radius),they get the wrong prompt (CFHLB4 instead of CFHLB3)
This is my profile:
CFHLB3# show profile
@terminal idle 240
@prompt CFHLB3
alias all reboot "@configure;boot;reboo"
alias all dnslookup "@script play dnslookup"
alias all aca-load "@script play service-load"
alias all save_config "copy running-config startup-config;archive startup-config"
alias all save_profile "copy profile user-profile;archive script \${USER}-profile"
alias all logon "@configure;logging line ${LINE};exit"
alias all logoff "@configure;no logging line \${LINE};exit"
alias all commit_redundConfig "@script play commit_redundancy"
alias all commit_VipRedundConfig "@script play commit_vip_redundancy"
alias all shutdown "@configure;boot;shutd"
alias super monitor "script play monitor"
alias super install-gui "script play install-gui"
alias super upgrade "script play upgrade"
alias super setup "script play setup"
set CHECK_STARTUP_ERRORS "1" session
Do i need to bound this profile to something?
Can anybody help?
THanks,
Kurt
Gilles Dufour Tue, 09/02/2008 - 04:48
There are multiple profiles.
One for each user.
Do a 'show archive ?' to see the last of -profile.
Then do a 'show archive -profile' to see what prompt it contains.
One way to change it is to login as this user, set the prompt and save the profile.
Gilles.
