Instaling second WS-X6K-SUP1A-2GE
Aug 14th, 2007
I have switch 6509 with a WS-X6K-SUP1A-2GE card,
I am going to install a WS-X6K-SUP1A-2GE second card .
The equipment at this moment is in production.
The cards have installed a WS-F6K-MSFC card .
The CATOS version is 7.6(1).
The IOS version of the msfc card is 12.0(7)XE1.
I do not know the software version, the card that
I am going to install, but believe that it is superior.
When i inserts the card, Automaticly will it
download the CATOS in engine and the IOS in
the MSFC of the second card, although the
versions in the second card are superior?.
will i need to restart the switch?. Do You Have some
documentation about this?.
ankbhasi Tue, 08/14/2007 - 08:05
  • Cisco Employee,
Hi Friend,
I will say be very carefull installing second sup engine when you are running CATOS. No worry about MSFCs because they never synch images automatically.
Will recommend you to read the link posted below carefully and come back if you have any doubts
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/sw_8_1/confg_gd/redund.htm#wp1046825
If you are clear after reading the doc go ahead.
Ankur
*Pls rate all helpfull post
