bgp aggregate-address
Aug 14th, 2007
If I am using the bgp 'aggregate-address' command do I need a network statement?
From testing, it does not appear to be necessary but is this good/bad practice?
Below is my proposed configuration, any suggestions you can share would be appreciated.
router bgp 65000
no synchronization
bgp log-neighbor-changes
aggregate-address summary-only
redistribute ospf 1
neighbor remote-as 65111
maximum-paths 5
no auto-summary
Overall Rating: 4 (2 ratings)
Jon Marshall Wed, 01/21/2015 - 18:18
You do not need a network statement to advertise out an aggregate address. As long as one of the networks that makes up the aggregate address is in the BGP table then the aggregate address will be advertised out.
Pavel Bykov Tue, 08/14/2007 - 08:59
Just like Jon confirmed, you do not need a network statement, but you do need a subnet from that range in the routing table.
But then you don't need "summary-only" keyword either.
For example if you would have the following config:
network mask
network mask
Then router would advertise:
And if you would use summary-only in this case, like this:
network mask
network mask
Than the router would only advertise The routes and would be SUPPRESSED, and not advertised to neighbors.
