Transferred to FailSafe conversation
Aug 14th, 2007
When users access their voice mail, and hit 2 to Send a message, the system disconnects with a message "This system is temporarily unable to complete your call.." and disconnects.
The App log has several items from
Source - CiscoUnity - ConvMsg
Event ID - 10013
Description:
Transferred to FailSafe conversation while running conversation AddrSearchConv on Port 42. See the following file for the contents of the Named Properties : e:\CommServer\Logs\\NPDump_20070814_091536.txt
For more information, click: http://www.CiscoUnitySupport.com/find.php
This is closely followed by PhraseServer Errors;
Cisco Unity's Phrase Server Manager experienced a serious error.
EXPLANATION:
Failed while calling a local method on a Phrase Server object.
TECHNICAL DETAILS:
Method: CAvPhraseServerMgr::CreatePhraseServerSU
Called Method: CreatePhraseServerSUByName
Parameters: AvAddrSearchENU
Error: 0x80004005 E_FAIL
Your help will be appreciated;
Ginger Dillon Thu, 08/16/2007 - 09:13
Hi - hope you don't mind me chiming in :-)
Customer is running Unity 4.0(4)SR1 with Installed Engineering Specials: CiscoUnity4.0(4)_ES23, CiscoUnity4.0(4)_ES35, CiscoUnity4.0(4)_ES46 and Exchange in failover configuration. From the attached log file.
Sincerely, Ginger
asomanya Fri, 08/17/2007 - 06:50
Resolved issue. Problem was related to wav files used by the directory handler.
toormehdi Fri, 08/29/2008 - 14:09
How was this solved? I am running into the same issue. Your help will be much appreciated.
