CMM image
Aug 14th, 2007
Native 6509 with CMM voice module. When upgrade IOS in the supervisor module, does the CMM module auto upgraded, is there a seperate module image for CMM that we apply seperately if need to upgrade CMM for some bug? Thanks
Overall Rating: 4 (1 ratings)
rob.huffman Tue, 08/14/2007 - 12:56
Hi CF,
CMM has its own software image; the image is not bundled with the supervisor engine or MSFC images.
Software Upgrade Procedure
From this doc;
Release Notes for the Cisco Catalyst 6500 Series and the Cisco 7600 Series Communication Media Module for Cisco IOS Release 12.3(8)XY
Hope this helps!
ciscoforum Wed, 08/15/2007 - 09:08
Thanks very much. So in order to configure CMM, we have to use session command going to the module and configure it as to the other module, like 6608? Thanks
rob.huffman Wed, 08/15/2007 - 09:34
Hi CF,
You are most correct :) You will use session command (session slot x processor 0) where x is your module number.
Hope this helps!
