AIR-LAP1310G-A-K9 & AIR-ANT3338
Aug 14th, 2007
Dear All,
Can i use AIR-ANT3338 with AIR-BR1310G-A-K9-R?
if yes what range it will give me in typical university campus?
my purpose it to distribute internet on 2.4 GHz wireless for university students.
AIR-ANT3338 is directional or ominidirectional ?
thax in advance
valstan Tue, 08/14/2007 - 13:26
Yes, you can. AIR-ANT3338 is an outdoor long-range directional connections antenna and it has 21 dBi gain and 12.4? H 12.4? V beam width. Approximate range at 2 Mbps 25 miles (40 km). Approximate range at 11 Mbps for Access Point is 11.5 miles (18.5 km).
ghugerajesh1 Wed, 08/15/2007 - 03:11
Thank for you reply
you mean it will support the laptop clients to connect to AP from 11.5 miles and can access to the internet ???
srosenthal Mon, 08/27/2007 - 07:45
No, it will not support clients out anywhere near that far unless they also have one of these antenna's on their laptop. The gain of a client wireless card is very little.
Also, any clients that are close enough to the antenna will also have to be in the beam of the 3338 as it is a very confined beam width.
Seth
ghugerajesh1 Mon, 08/27/2007 - 09:17
Thanks seth
your suggetions are really helpful.
I have decided to use AIR-ANT24120 (Cisco Aironet 2.4-GHz, 12-dBi omnidirectional mast-mount antenna) with AIR-BR1310G-A-K9-R. this AP will be at central location and other AP AIR-BR1310G-A-K9 will connect to centralised AP with "bridge with client" configuration.
hope i am going in rt direction.
valstan Tue, 08/28/2007 - 06:18
Hi ghugerajesh1,
I was giving you a tech data for this antena. You could use it to bridge different building in the campus.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
