Routers for VPLS
Aug 14th, 2007
Which is the lowest series router i need to test VPLS or Pseudowire in LAB?
Will 26XX or 37XX will support the VPLS and Pseudowire testing?
swaroop.potdar Tue, 08/14/2007 - 13:17
For VPLS in terms of series the smallest is 76xx.
Pseudowire, you can test starting with 72xx.
HTH-Cheers,
Swaroop
asb19 Thu, 08/16/2007 - 00:49
Also, PWE at 72xx will allow only p-t-p links. No p-t-m (as it is possible with VPLS).
jander2008 Wed, 02/20/2008 - 09:44
Hi Swaroop:
For those of us who have no access to 7600's n a lab environemnt, can the 7600's be emulated using DynaMips in a laptop?
I also have access to 2 7507's running rsp-k91pv-mz.122-25.S9.bin with 3640's as CE's
I would like to learn/test out VPLS and AToM.
Is it possible?
Thanks.
GREGORY GEE Mon, 03/03/2008 - 13:14
Unfortunately, at this moment, Dynamips still doesn't support 6500/7600 and VPLS is only on 6500/7600/12000.
AToM is available on lots of other platforms.
Greg
