Allowing ASDM access using the "http x.x.x.x"
Aug 14th, 2007
This is strange.
My ASDM workstation IP is 192.168.1.2
My ASA is 192.168.1.1
I cannot access the ASA with ASDM if I have the following line in my config:
http 192.168.0.0 255.255.0.0 inside
However, I *CAN* access the ASA if I change the line to be:
http 192.168.1.0 255.255.255.0 inside
That doesn't make much sense to me.
Basically I'm setting up a network of ASAs all on 192.168.x.x and I want to be able to access them with ASDM anywhere in my internal network, so I figured the more general "http 192.168.0.0 255.255.0.0" config line would be the proper way to do it, but it seems I can only use a more "specific" config line.
Anyone have any ideas why this is happening???
thomasdzubin Tue, 08/14/2007 - 13:26
So are you saying I have to have a separate "http 192.168.x.0 255.255.255.0" for all the networks that I'm going to be using ASDM from? Yuck.
