concentrator site to site vpn problem
Aug 14th, 2007
have recently downloaded a document from the cisco website
that states that you can configure a 3000 vpn concentrator
to set up a lan to lan vpn from from a pix firewall that
gets its outside address from dhcp.
apparently to get this to work you have to configure the
concentrators Base Group like this
on the General tab
Tunneling Protocols = IPSec
on the IPSec tab
Tunnel Type = Remote Access
Authentication = None
and set the Default Preshared Key (in this case its cisco123)
i've set the Base Group to use IPsec SA ESP-3DES-MD5
which in turn uses the IKE-3DES-MD5 IKE Proposal
which match the phase 1 and phase 2 in the configuration
of the pix firewall
PIX CONFIG
interface ethernet0 100full
ip address outside 192.168.2.1 255.255.255.0
interface ethernet1 100full
ip address inside 192.168.1.1 255.255.255.0
access-list 101 permit ip 192.168.1.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list 102 permit ip 192.168.1.0 255.255.255.0 192.168.3.0 255.255.255.0
nat (inside) 1 192.168.1.0 255.255.255.0
global (outside) 1 interface
nat (inside) 0 access-list 101
route outside 0.0.0.0 0.0.0.0 192.168.2.2
crypto ipsec transform-set REMOTE_VPN esp-3des esp-md5-hmac
sysopt connection permit-ipsec
crypto map vpn 10 ipsec-isakmp
crypto map vpn 10 match address 102
crypto map vpn 10 set peer 192.168.2.2
crypto map vpn 10 set transform-set REMOTE_VPN
crypto map vpn interface outside
isakmp enable outside
isakmp identity address
isakmp key cisco123 address 192.168.2.2 netmask 255.255.255.255
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
after all this i am unable to get a tunnel to come up
from the Live Event Log on the concentrator
i get this output when attempting to connect
24 08/14/2007 16:43:50.350 SEV=4 AUTH/9 RPT=4 192.168.2.1
Authentication failed: Reason = No active server found
handle = 3, server = (none), user = VPNC_Base_Group
i've included the output from debug crypto isakmp
on the firewall on an attachment as its a bit long
any ideas on why i am unable to establish a tunnel
will be appreciated.
Melvyn Brown
ps i know the config states that the pix has a static address
but i used this config when setting up a similar thing into
a pix 515 and it worked perfectly.
