Moving D channel to channel 0 when configuring NFAS
Aug 14th, 2007
A colleague of mine (honestly :) is configuring a router with 5 T1 PRI's. The provider is working with him to configure NFAS so he can utilize the remaining D channels on the other T1's for B channel functions.
The problem he is running into, is that the Carrier setup the signaling on DS0 of the first T1.
Is there a way to change the signalling channel to not use channel 24?
He's already read this site:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_configuration_guide_chapter09186a008020ecee.html
-Scott
paolo bevilacqua Tue, 08/14/2007 - 18:45
  • Hall of Fame,
    Founding Member
No way, actually he should also ask to have a backup of the D channel on another circuit.
In any case if he still in time to rethink about the whole issue he should consider regular pri instead as a gain of 3 channels over 115 is not worth the added complexity in most cases.
