PIX as a router
Answered Question
Aug 14th, 2007
Hello Guys need your guidance!
Is it possible to use the PIX 515E as a router? See the link below for the network topology.
http://img259.imageshack.us/img259/2831/pixasarouterns1.jpg
Referring to the network topology. The client want that the two subnets (192.168.1.0/24 and 192.168.2.0/24) can access each other. In addition, both subnets be able to access the web.
Correct Answer by Jon Marshall about 9 years 5 months ago
It would be a lot easier if it is version 7.x
What you can do is make the 2 interfaces that connect to your internal subnets the same security level. Then add the following command to your config
same-security-traffic permit inter-interface
This will allow traffic to flow freely between those 2 subnets without access-lists or NAT statements.
Jon
Overall Rating: 4 (1 ratings)
Jon Marshall Tue, 08/14/2007 - 16:58
Yes you can do this. Presumably you have 3 interfaces on the pix firewall ?
How you set this up depends on what version of code you are running on your pix ie. v6.x or v7.x.
Which version are you running on your pix ?
Jon
Rejohn Ronald Cuares Tue, 08/14/2007 - 23:10
It has 6 interfaces. I still dont know the version of the Pix 515E however im sure it is 7.x coz it was bought last year 2006.
By the way each subnet contains 100+ users.
Correct Answer
Jon Marshall Tue, 08/14/2007 - 23:29
Jon
