HSRP vs VRRP
Aug 14th, 2007
I would appreciate if any body would let me know the advantages of using VRRP over HSRP in a cisco environment (Cisco Switch & router).
My colleagues are explaining me to use VRRP over HSRP but I am trying ro explain them to use HSRP.
I would appreciate if some body can send me details of advantages of using HSRP over VRRP so that I can get my colleagues convinced to use HSRP.
Thanks in advance
Edison Ortiz Tue, 08/14/2007 - 19:13
  • Hall of Fame,
    Founding Member
They both offer the same type of service, the main difference is, HSRP is Cisco proprietary while VRRP is not. If you plan to design a 'first hop redundancy' solution where different hardware vendors come into play, VRRP will be the right choice. If you are sure you are going with Cisco and Cisco only, HSRP will be the right choice.
tromer Tue, 08/14/2007 - 20:07
Object tracking was missing in VRRP at one point, but it's there in 12.3(2)T and up.
Not sure if VRRP supports advanced tracking using IP SLA reachability tests. I know HSRP does.
VRRP automatically preempts too.
I agree with the above post.
hth,
Ted
