08-14-2007 07:46 PM - edited 03-05-2019 05:54 PM
Hi all !!
I'd like to config private vlan on Cisco Switch module 3020 ( for HP Chassis ). But IOS do not support (cbs30x0-lanbase-mz.122-25.SEF1/cbs30x0-lanbase-mz.122-25.SEF1.bin ).
Please tell me which IOS version can support this feature.
Thanks a lot !!
08-14-2007 11:07 PM
The 3020 does not fully support private vlans. What it does support is PVLAN Edge (Protected ports). This allows you to isolate ports on the same switch but not across switches.
Attached is the config section for the 3020 that deals with protected ports.
http://www.cisco.com/en/US/products/ps6748/products_configuration_guide_chapter09186a0080814447.html
Jon
08-15-2007 12:24 AM
thanks !
I consider Layer 2 security for customer. I think there's no IOS to upgrade to support this feature for C3020, doesn't it?
thanks again !
