IPS 6 - virtual IPS?
Aug 14th, 2007
IPS 6 can make virtual IPS, likely FWSM can make virtual Firewall ?
Anybody have the link for IPS 6 can make virtual IPS?
amritpatek Tue, 08/21/2007 - 06:12
The Virtual Sensors page is where you create, name, and configure virtual sensors on your Cisco IPS devices. A virtual sensor is a logical grouping of sensing interfaces and the configuration policy for the signature engines and event action filters to apply. The process of creating and naming virtual sensors on your Cisco IPS devices is sometimes called "virtualization." Virtualization is the separation of a single physical IPS device into two or more logical devices on the basis of port, IP address range, VLAN tag, and other criteria
mhellman Tue, 08/21/2007 - 08:28
tread carefully, Cisco doesn't appear to quite have all the kinks worked out of virtual sensors. The last upgrade deleted any that didn't start with "sig"...so all ours were deleted. a fix is imminent for this particular issue.
