IRB over VPN
Aug 14th, 2007
I've seen previous posts in this forum stating that in order to "transparently bridge" a connection over a VPN between two routers it's as simple as using IRB on the GRE over IPSEC tunnel.
I've configured the routers (837 <-> 877) and the GRE over IPSEC appears to be up but I'm not sure where to go from here.
Can anyone offer some pointers on the next step please?
The Ethernet interfaces of each router are on the same subnet but they are on different sites and connected via ADSL with static IP addresses.
I can post the configs to here if required.
Thanks in advance.
Andrew
pija Thu, 08/30/2007 - 16:50
I assume that your GRE over IPSec configuration is working thus it's enough to add IRB related lines in global config as well as interface mode. An example of such a configuration attached below. Enjoy!
Testing topology:
[Host 10.0.0.1]-----[10.0.0.2 (R2) 192.168.2.2]-------[Frame-Relay]-------[192.168.2.5 (R5) 10.0.0.3]-----[10.0.0.4 Host]
The partial configuration of R2 (R5 is symmetrical):
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key cisco address 192.168.2.5 no-xauth
crypto ipsec transform-set vpn esp-3des esp-md5-hmac
crypto map VPN 1 ipsec-isakmp
set peer 192.168.2.5
set transform-set vpn
match address 140
bridge irb
interface Tunnel1
no ip address <--- you can assign IP addresss, this is not necessary.
tunnel source 192.168.2.2
tunnel destination 192.168.2.5
bridge-group 1
interface Ethernet0/0
no ip address
bridge-group 1
interface Serial1/0
no ip address
encapsulation frame-relay
interface Serial1/0.1 point-to-point
ip address 192.168.2.2 255.255.255.252
frame-relay interface-dlci 203
crypto map VPN
interface BVI1
ip address 10.0.0.2 255.255.255.0
access-list 140 permit gre host 192.168.2.2 host 192.168.2.5
bridge 1 protocol ieee
bridge 1 route ip
wormscoffer Fri, 08/31/2007 - 05:49
Thanks pija
I'd posted the same question in a couple of forums and your reply is the most comprehensive and easiest to understand.
I'll give this a try.
Many thanks.
