7940/7960 unregister/register
Aug 14th, 2007
Hi, Do anyone encouter this issue?
it seems that it was a tcp issue...can anyone help me on this?
tnx
ccm_567300000196.txt:08/02/2007 20:31:10.657 CCM|StationInit: (0000000)
alarmSeverity=2 text="13: Name=SEP001xxxxxx Load=8.0(6.0)
Last=CM-aborted-TCP" parm1=2049(801) parm2=261208330(f91b90a).|
<CLID::StandAloneCluster><NID::x.x.x.x><CT::1,100,119,1.48034359>
<IP::x.x.x.x><DEV::>
hadbou Mon, 08/20/2007 - 14:14
  • Bronze, 100 points or more
Workaround:
Either implement CTL on the system, or ignore the alarm message.
Further Problem Description:
The loader will report a file not found error if any file it looks for is not found on the server. This includes the .loads file, the .sbn file and the CTL file. Of these files, the CTL file is optional.
