3825 Voice Gateway with ISDN E1 line
Aug 15th, 2007
Hi all,
I have 1 Cisco 3825 Router with module NM-1CE1T1-PRI
And i have one line E1 connect to this
I have configed Cisco AS5300 work with E1 line and callmanager, but with 3825 i have some problem
Any one can send me config example with 3825 router to accept incoming call and forward to callmanager
Thanks alot, vote 5* for your help
Overall Rating: 5 (1 ratings)
conkinkinconkinkin Wed, 08/15/2007 - 21:00
Any one have configed Cisco Router 3825 to work with ISDN E1 line and callmanager?
Can you share your config sample?
Thanks alot
thomasarun Thu, 08/16/2007 - 00:49
Let me know which protocol you want to use?
H.323 or MGCP?
conkinkinconkinkin Sun, 08/19/2007 - 10:19
I use H323 protocol
On my router 3825 i use "NM-1CE1T1-PRI" module
This module support E1 and T1 line
I use command "card type E1", and i can see interface from 0-30, E1 port on module is port 1/1.
But after config channel 15, i didn't find command to config voice port 1/1:D
(with E1 module, voice port is config to receive incoming call, and place out going call)
May be have some different with module NM-1CE1T1-PRI
Any one can help, thanks
royalblues Sun, 08/19/2007 - 11:16
  • Green, 3000 points or more
here's a sample config from a router running H323
isdn switch-type primary-net5
controller E1 0/2/0
framing NO-CRC4
pri-group timeslots 1-31
interface Serial0/2/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn send-alerting
isdn sending-complete
no cdp enable
voice-port 0/2/0:15
dial-peer voice 1 voip
destination-pattern
session target ipv4:
dtmf-relay h245-alphanumeric
codec g711ulaw
Narayan
conkinkinconkinkin Mon, 08/20/2007 - 00:29
Thanks Narayan, i vote 5* for your help
I have configed ISDN E1 with AS5300
But with this module i did not see voice-port :15 to config
Do you see this problem before? May be line E1 down or i did not config right ?
I user NM-1CE1T1-PRI module, after change card type to E1, i see all channel 0-30 but can not see voice port :15
conkinkinconkinkin Thu, 09/06/2007 - 03:05
Hi, all
Any one configed module NM-1CE1T1-PRI for voice.
After i config controller on e1 interface, config linecode, framing, pri timeslot, I didn't see any "voice port"
I sure that linecode, framing, e1 line is ok, because i use this e1 line with AS5350 and all thing run well
May be have some problem with module NM-1CE1T1-PRI. Do this module support Voice??
Or have some problem in hardware?
Thanks for all help
conkinkinconkinkin Fri, 09/07/2007 - 20:42
I use line E1, after config
"controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-31 "
I see interface serial 1/0:0-1/0:30
And I config interface serial1/0:15( d channel)
"interface Serial1/0:15
no ip address
encapsulation hdlc
isdn incoming-voice modem 64
no cdp enable
But after that, i did not see any voice port while type "show run"
I use software Version 12.4(13b)
pklos Tue, 09/11/2007 - 03:12
  • Silver, 250 points or more
Do you have network-clock-select command?
And I think you should have "incoming-voice voice" instead modem 64.
regards,
pk
thomasarun Tue, 09/11/2007 - 21:21
You can try one more command in controller E1
'clock source still if it is not showing u can change the IOS to 12.4T
conkinkinconkinkin Thu, 09/13/2007 - 00:55
Thanks thomasarun
I upgraded new software, new version is:
"Cisco IOS Software, 3800 Software (C3825-IPVOICEK9-M), Version 12.4(4)T8, RELEASE SOFTWARE (fc3)"
"Cisco 3825 (revision 1.0) with 226304K/35840K bytes of memory.
Processor board ID FHK0949F0LM
2 Gigabit Ethernet interfaces
31 Serial interfaces
1 Channelized E1/PRI port
4 Voice FXO interfaces
8 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)"
But after try each of: clock source external, line, external, voice port 1/0:D did not show (my E1 port is 1/0)
May be this module NM-1CE1T1-PRI have some different in configuration.
Any one can help?
thomasarun Thu, 09/13/2007 - 02:40
card type e1
Controller E1
framing
linecode
clock source
then can u give the sh run details.
conkinkinconkinkin Sun, 09/16/2007 - 18:56
Thanks thomasarun
here is my 3825 configuration:
GW#sh run
Building configuration...
card type e1 1
ip subnet-zero
ip cef
no ip domain lookup
voice-card 0
no dspfarm
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
h323
no h225 timeout keepalive
no call service stop
call start slow
voice class codec 1
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g711ulaw
voice class h323 1
h225 timeout tcp establish 3
telephony-service ccm-compatible
ccm-compatible
fax interface-type fax-mail
controller E1 1/0
framing NO-CRC4
clock source internal
interface GigabitEthernet0/0
ip address 192.168.10.100 255.255.255.0
duplex auto
speed auto
media-type rj45
negotiation auto
h323-gateway voip interface
h323-gateway voip h323-id h323Gateway
h323-gateway voip bind srcaddr 192.168.10.100
no ip address
encapsulation hdlc
isdn switch-type primary-4ess
isdn send-alerting
no cdp enable
interface Dialer0
no ip address
interface Group-Async0
physical-layer async
no ip address
encapsulation ppp
dialer in-band
dialer idle-timeout 900
no group-range
ip default-gateway 192.168.10.1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.10.1
control-plane
dial-peer voice 19 voip
answer-address 19..
dial-peer voice 9 pots
destination-pattern 9T
dial-peer voice 2 voip
preference 1
destination-pattern 1...
voice-class codec 1
voice-class h323 1
session target ipv4:192.168.10.200
no call fallback
no vad
dial-peer voice 1 pots
answer-address .
gateway
timer receive-rtp 1200
line con 0
stopbits 1
line aux 0
modem InOut
transport input all
stopbits 1
scheduler allocate 20000 1000
end
GW#
And here is output about all module
NAME: "PVDMII DSP SIMM with four DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64 , VID: NA , SN: FOC094432Q8
NAME: "One Port Channelized E1/T1/PRI with Integrated CSU on Slot 1", DESCR: "One Port Channelized E1/T1/PRI with Integrated CSU"
PID: NM-1CE1T1-PRI= , VID: 1.0, SN: FOC09360EZ8
conkinkinconkinkin Mon, 09/17/2007 - 02:11
My E1 interface is on slot 1, port 0
After config controller e1 1/0, i config network-clock-select but see:
GW(config)#network-clock-select 1 e1 1/0
% Incomplete command.
GW(config)#network-clock-participate slot 1
Slot is empty or does not support clock participate
And when config voice card i see the
GW(config)#voice-card 1
% Invalid input detected at '^' marker.
GW(config)#voice-card 0
GW(config-voicecard)#
My E1 interface on slot 1, i cannot config voice card 1
conkinkinconkinkin Wed, 09/26/2007 - 19:36
Thanks all,
My problem is module NM-1CE1T1-PRI don't support voice.
If you wan to support voice you need module like:
NM-HDV2-1T1/E1(IP Communications High-Density Digital Voice NM with 1 T1/E1)
NM-HDV2-1T1/E1=(IP Communications High-Density Digital Voice NM with 1 T1/E1)
NM-HDV2-2T1/E1(IP Communications High-Density Digital Voice NM with 2 T1/E1)
NM-HDV2-2T1/E1=(IP Communications High-Density Digital Voice NM with 2 T1/E1)
or
VWIC2-1MFT-T1/E1
