Transcoding
Aug 15th, 2007
I can't get a router to register as a transcoding in CCM 5.1. It keeps coming up saying rejected. I have configured this many times on CCM4.1 without any issues. Did something change?
mchandak Wed, 08/15/2007 - 06:14
  • Gold, 750 points or more
What Router, NM/DSP do you have and can you paste the config and show sccp from the router.
mchandak Wed, 08/15/2007 - 08:31
There is no config attached, so can you check if the Name used in this profile matches with the CM configuration.
Chris Deren Wed, 08/15/2007 - 06:33
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
When you build your sccp confiuration, try not using the CM version, or use 4.1. What IOS version are you running?
Chris
chris.damore Wed, 08/15/2007 - 11:37
The router is running c2800nm-advipservicesk9-mz.124-3g.bin.
