uploading a text config
Answered Question
Aug 15th, 2007
If my CatOS switch is configured with "set config mode text", can I upload a config just by pasting the entire config at the prompt and it will run through it line by line like on a IOS switch?
Correct Answer by Pavel Bykov about 9 years 7 months ago
Yes you should be able to do that.
No, you don't need to format or change anything and you should be able to paste the list as-is. (assuming it's not hand-written but from other installation or system)
Overall Rating: 5 (1 ratings)
Pavel Bykov Wed, 08/15/2007 - 08:52
  • Silver, 250 points or more
As far as I know it should work in binary mode as well.
Difference between binary and text modes is the way the configuration is stored, and that in text mode you need to save it manually. But besides that, the commands should be pasteable without problem in any mode.
MZydorczyk2 Wed, 08/15/2007 - 08:56
So I would be able to take an entire list of commands and paste them in all at once for it to execute one by one? Would I need to format the list of commands a certain way?
Correct Answer
Pavel Bykov Wed, 08/15/2007 - 09:03
