What module to use?
Answered Question
Aug 15th, 2007
For a 3800 series router, what module can i use for a dedicated 100MB fiber connection.
Correct Answer by royalblues about 9 years 8 months ago
The 3800 series routers come with one dual purpose Gigabit port. By defualt the media-type is RJ-45.
You can use the SFP module (GLC-SX-MM= , if it is multimode)on this port and change the media-type to support fiber.
interface gi 0/0
media-type SFP
HTH, rate if it does
Narayan
Overall Rating: 5 (1 ratings)
Correct Answer
royalblues Wed, 08/15/2007 - 06:32
  • Green, 3000 points or more
interface gi 0/0
media-type SFP
Narayan
tromer Wed, 08/15/2007 - 06:35
The model below seems to support a "SFP" module. That may be your only option for a 100Mb Fiber (ethernet). I don't remember if the 3800 has SFPs onboard. If they do, you don't need the switch module just the SFP.
NME-XD-24ES-1S-P
Link:
http://www.cisco.com/en/US/products/ps5855/products_data_sheet0900aecd8028d15f.html
Fiber SFPs:
http://www.cisco.com/en/US/products/hw/modules/ps5455/products_data_sheet0900aecd8033f885.html
