Ordering POTS Line
Answered Question
Aug 15th, 2007
I've been given the task to order POTS lines for inbound and outbound. Will use a 2851 with the VIC2-4FXO. Is their any specific POTS line I have to order or can I say I need 4 POTS lines.
Correct Answer by Rob Huffman about 9 years 9 months ago
Hi Steven,
That should work :) Different Providers will have different names for these such as;
IBL - Individual Business Line
SLB - Single Line Business
Ordering 4 Single POTS Business Lines (Loop Start) should get the job done with any Telco.
Hope this helps!
Rob
Correct Answer by Chris Deren about 9 years 9 months ago
You may be asked what signailing type you want to use, either Loop start or Ground Start, either one is fine, prefered one is ground start but loop start is most common.
POTS lines are just like your phone line at home (assuming you are not running VoIP).
Chris
Overall Rating: 5 (2 ratings)
Correct Answer
Chris Deren Wed, 08/15/2007 - 06:32
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Chris
Correct Answer
Rob Huffman Wed, 08/15/2007 - 06:34
  • Hall of Fame,
    Founding Member
    2017 IP Telephony, Unified Communications
Hi Steven,
Hope this helps!
Rob
