ASDM can't see routes
Aug 15th, 2007
When using the ASDM I go to monitoring > routing > routes but there are no routes listed. If I telnet in and do a show route, they are all there. Am I not using the product correctly?
acomiskey Wed, 08/15/2007 - 06:40
You are using it correctly and the routes should display. Have you tried the "Refresh" button? What version of ASDM?
jgadbois Wed, 08/15/2007 - 08:24
Yes. Tried the refresh button many times with no results. I am using ASDM version 1.5(22)which is 6.02 I believe.
dcoghlan Sun, 09/21/2008 - 20:23
I am also having this problem on a PIX515E I am running. It is running 7.2(3) with ASDM 5.2(3). I have upgraded it to asdm 5.2(4) and the issue is still there. Any help on this would be appreciated.
the only error I get is in the bottom left hand corner of the ASDM "Error in getting/parsing the monitoring data"
