Need a review of my Lab Setup CCNP
I nailed my CCNA last November, and want to get my CCNP this November. I have started purchasing and/or quoting out equipment, but I wanted a quick review before I buy everything.
Currently I have:
2x2500 Routers (for my CCNA .. probably not too useful anymore except as hubs)
1x1841 Router
1x2511 Access Server (need to find a config guide for this)
1x3750G Switch (went for the Gig version so that is is useful to me when not training.
2x2950 Switches w/ Advanced IP Services IOS.
1x1721 Router in use as my DSL Modem
1x Pix 506e in use as my firewall
1x Pix 501 for playing around on.
[pending]
4 3640 routers with serial and Ethernet cards
Maybe another 1841 router.
Goals: CCNP in the near future, Firewall specialist eventually and long range I may consider CCIE Switching & Routing.
Questions: any good lab guides/scenario resources others have used? I also need a sample config for the Access-Server setup, and any handy programs for remotely accessing everything. I am planning on training quite a bit away from home, so the idea is to VPN in and turn on equipment via an APC master switch [already purchased].
steve_steele Thu, 08/16/2007 - 23:33
  • Bronze, 100 points or more
For the Access Server
Create a loopback and give it an IP
interface Loopback0
ip address 192.168.0.1 255.255.255.0
Then map the Async ports to the loopback using the names of your equipment
ip host ROUTER6 2008 192.168.0.1
ip host ROUTER5 2007 192.168.0.1
ip host ROUTER4 2006 192.168.0.1
ip host ROUTER3 2005 192.168.0.1
ip host ROUTER2 2004 192.168.0.1
ip host ROUTER1 2003 192.168.0.1
ip host SWITCH2 2002 192.168.0.1
ip host SWITCH1 2001 192.168.0.1
plug Async Line 1 into SWITCH1,line 2 into SWITCH2 etc.
plug in the appropriate lines of the async cable.
simply type SWITCH1 to reverse telnet to SWITCH1 etc...
Think that I covered everything.
Steve
