Remove statement
Answered Question
Aug 15th, 2007
How do I remove the statement "no ip mroute-cache" from my vlan config
interface Vlan315
description AGS
ip address 10.10.20.1 255.255.252.0
ip helper-address 10.4.48.1
ip helper-address 10.4.55.5
no ip mroute-cache
I had Multicast routing on with the statement "ip pim dense-mode" under the vlan. I removed the multicast routing then removed the statement "ip pim dense-mode" under the vlan and then it auto added the statement "no ip mroute-cache"
Correct Answer by Edison Ortiz about 9 years 8 months ago
Enter
"ip mroute-cache"
Default commands will not be visible in the config and by default ip mroute-cache is enabled on SVIs.
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Wed, 08/15/2007 - 07:51
  • Hall of Fame,
    Founding Member
Enter
"ip mroute-cache"
albolabris Wed, 08/15/2007 - 08:15
It's telling me its an Incomplete command
CO-1-MDF(config)#int vlan 315
CO-1-MDF(config-if)#ip mroute-cache
% Incomplete command.
albolabris Wed, 08/15/2007 - 08:20
I found it its "ip mroute-cache distributed"
Thank you...
Edison Ortiz Wed, 08/15/2007 - 09:01
  • Hall of Fame,
    Founding Member
You need the distributed option because multicast fast-switching is done in hardware instead of software on that particular switch.
