Dual Power Supply Question for 6509s
Answered Question
Aug 15th, 2007
Is there a command to tell the switch to make use of both power supplies rather than having one serve as a standby?
Correct Answer by bussell@csdg.com about 9 years 6 months ago
power redundancy-mode
To set the power-supply redundancy mode, use the power redundancy-mode command.
power redundancy-mode {combined | redundant}
Syntax Description
combined
Specifies no redundancy (combine power-supply outputs).
redundant
Specifies redundancy (either power supply can operate the system).
Defaults
redundant
Command Modes
Global configuration
Command History
Release Modification
12.0(7)XE
Support for this command was introduced on the Catalyst 6500 series switches.
12.1(1)E
Support for this command on the Catalyst 6500 series switches was extended to the 12.1 E release.
Examples
This example shows how to set power supplies to the no-redundancy mode:
Router(config)# power redundancy-mode combined
Router(config)#
This example shows how to set power supplies to the redundancy mode:
Router(config)# power redundancy-mode redundant
Router(config)#
Related Commands
show power
http://www.cisco.com/en/US/partner/products/hw/switches/ps708/products_command_reference_chapter09186a00801026f8.html#wp1047426
Overall Rating: 5 (1 ratings)
Correct Answer
bussell@csdg.com Wed, 08/15/2007 - 11:12
Syntax Description
combined
redundant
Defaults
redundant
Command Modes
Command History
12.0(7)XE
12.1(1)E
Examples
Router(config)#
Router(config)#
Related Commands
show power
