QoS Sanity Check! need help Now.
Aug 15th, 2007
  • Blue, 1500 points or more
I have a 3560 L3 switch that is connected to a MAN network in a funny way.
the outward-facing port is configured as a trunk to pass vlan traffic across the metro fiber to a distant-end 6513 L3 switch. It also is placed in a vlan to pass L3 traffic across that same metro fiber.
Here is the config of that port:
interface GigabitEthernet0/1
description Connection to TLS
switchport access vlan 21
switchport trunk native vlan 21
switchport mode trunk
load-interval 60
The access ports are configured accordingly:
interface range FastEthernet0/1 - 24
description 10 / 100 Port
switchport mode access
switchport nonegotiate
load-interval 60
mls qos trust cos
speed auto
duplex auto
spanning-tree portfast
spanning-tree guard root
HERE IS THE QoS POLICY I WANT TO IMPLEMENT:
mls qos
class-map voip
match ip dscp ef
class-map hb
match access-group 100
class-map data
match access-group 101
policy-map TLS
class voip
set ip dscp ef
class hb
set ip dscp af41
class data
set ip dscp af31
interface g0/1
priority-queue out
service-policy output TLS
Access-list 100 permit tcp any any eq 580
Access-list 100 permit udp any any eq 580
Access-list 101 permit ip 172.16.0.0 0.0.1.255 any
So, I want to classify and mark VoIP traffic, server heartbeat traffic and general data. No biggie.
And then I want to apply that QoS policy to the outward-facing gi0/1 metro fiber interface.
PROBLEM:
Everytime I try to enter the "service-policy output TLS" command, it says "Warning: Applying service policy to OUTPUT interface not supported"
Im confused. Dont I HAVE to apply it to the output so that the traffic LEAVING the 3560 and heading out to the outside world gets QoS'ed???
jwdoherty Wed, 08/15/2007 - 11:14
Believe outbound service policies not supported on that platform. You can mark with an inbound policy.
pciaccio Wed, 08/15/2007 - 11:20
  • Silver, 250 points or more
You need to apply your service-policy to a layer 3 interface. You need to configure Interface VLAN 2 and apply an IP address accociated with that VLAN. Then you can apply your Service-policy to it on the outbound traffic.... You cannot apply a service-policy to a layer 2 Trunk.. Try it out..Good Luck... Please rate...
lamav Wed, 08/15/2007 - 12:12
I changed it to service-policy intput and it took.
Pciacco does raise an interesting point:
is it the case that a service policy cannot be applied to a trunk port? I was thinking the same thing, but a QoS guru is th eone who wrote this part of the deployment. I asked the same question, but he seemed to think it would work.
Is he wrong?
royalblues Wed, 08/15/2007 - 13:33
  • Green, 3000 points or more
Lamav,
3560 does not support service-policy on the egress. It supports only inbound on the port and hence it took the command when you mentioned service-policy input.
Narayan
