HELP
Aug 15th, 2007
I am having a major issue with a CallManager 5.1.2 install. We are unable to call any CTI Route Points that are configured to forward calls to voice mail. I can also not call forward all to voice mail from any phone. iDivert also isn't working.
HELP!!!!
Rob Huffman Wed, 08/15/2007 - 11:55
Hi Chris,
The thing that these 3 issues have in common is the Unity VM Pilot # config in CCM. Can you check this out first.
Hope this helps!
Rob
chris.damore Wed, 08/15/2007 - 11:57
I have look at the pilot number, it looks fine to me. I am able to dial 8000 (VM pilot number) from the phones just fine.
Rob Huffman Wed, 08/15/2007 - 12:18
Hi Chris,
Did you check the checkbox for 8000;
Make this the default Voice Mail Pilot for the system
And then reset?
Rob
chris.damore Wed, 08/15/2007 - 12:26
Yep, tried it. I really don't understand what is going on with this.... I can call forward all my phone to voice mail and you get a message saying sorry or call can't be completed at this time. But I can hit the messages button and it works just fine.
Rob Huffman Wed, 08/15/2007 - 12:38
Hi Chris,
Interesting!? Did you check all the Call Forward All CSS settings? You certainly could have one working without the other. The Message Button is associated with the VM Pilot Config we were speaking of earlier. You can also try "hard coding" the Call Forward All Number rather than using the VM Checkbox on the DN configuration page.
Rob
