Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Wed, 08/15/2007 - 12:17
I''m not aware of any 100base-FX GBIC transceivers in the industry, so either you get a 100base-FX board for the switches, or add a switch with SFP ports, or use a media converter.
Paolo Bevilacqua Wed, 08/15/2007 - 12:53
Absolutely. Worst case the media converter will be at their end and their responsibility. Thanks for the rating and good luck!
