871W Router Wireless to Wireless Communication
Answered Question
Aug 15th, 2007
I have an 871W router with a couple of clients connected. If 2 devices are both connected to the router the devices cannot ping each other. I can ping both devices from the router but not from the device. If I connect 1 of the devices to the ethernet switch of the router than I am able to ping the device from the other device. Any ideas why I cannot ping the device from the other device when both are wireless?
Correct Answer by paolo bevilacqua about 9 years 8 months ago
try configuring:
interface Dot11Radio0
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
Overall Rating: 5 (2 ratings)
paolo bevilacqua Wed, 08/15/2007 - 12:21
  • Hall of Fame,
    Founding Member
Please send router configuration.
Correct Answer
paolo bevilacqua Thu, 08/16/2007 - 04:47
  • Hall of Fame,
    Founding Member
try configuring:
nrosselli Thu, 08/16/2007 - 04:50
Thank you for the quick response. I will try this and let you know how it goes.
nrosselli Thu, 08/16/2007 - 18:42
Your config changes got it working. Thanks for your help. Would you mind explaining why I needed these commands to enable this type of access?
paolo bevilacqua Fri, 08/17/2007 - 03:17
  • Hall of Fame,
    Founding Member
As you see the radio interface works bridged to BVI interface. But being an AP, it is a special kind of bridge.
The commands (no source-learning) allows that a packet received on the radio interface is also sent to all the other connected wireless devices.
Thanks for the nice rating and good luck!
tromer Thu, 08/16/2007 - 10:13
It might be your ACL, try this.
access-list 100 permit icmp any any echo
The echo requests may be getting blocked.
hth
ted
paolo bevilacqua Thu, 08/16/2007 - 10:27
  • Hall of Fame,
    Founding Member
But it doesn't appear the ACL is blocking any traffic, and cisco's ACLs are supposed to behave in a predictable way.
