3750 Access Port Question
Aug 15th, 2007
I have a 3750 port configured in Access Mode:
interface FastEthernet1/0/9
switchport access vlan 2
switchport mode access
switchport voice vlan 5
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
spanning-tree portfast
spanning-tree bpduguard enable
I have configured "trust cos", but I'm skeptical to whether that would work on an access port. Shouldn't I use "trust dscp" instead there?
Also, why in Access mode am I getting COS matches, since the traffic should be untagged:
OIGH-CRS01#sh mls qos int f1/0/9 st
FastEthernet1/0/9
dscp: incoming
0 - 4 : 288157 0 0 0 0
5 - 9 : 0 0 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 8828
25 - 29 : 0 0 0 0 0
30 - 34 : 0 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 0 0 0 0 0
45 - 49 : 0 165895 0 0 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 0 0 0 0
60 - 64 : 0 0 0 0
dscp: outgoing
0 - 4 : 487606 0 0 0 0
5 - 9 : 0 0 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 0
25 - 29 : 0 0 0 0 0
30 - 34 : 0 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 0 0 0 0 0
45 - 49 : 0 2437 0 40090 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 0 0 0 0
60 - 64 : 0 0 0 0
cos: incoming
0 - 4 : 289904 0 0 8828 0
5 - 7 : 165895 0 0
cos: outgoing
0 - 4 : 684606 0 0 0 0
5 - 7 : 2437 0 40252
Policer: Inprofile: 0 OutofProfile: 0
Overall Rating: 3 (2 ratings)
Paolo Bevilacqua Wed, 08/15/2007 - 13:10
Hi, I'm not sure about the qos settings as I personally never found them to be necessary, however consider that voice traffic from phone is tagged vlan 5 and can carry COS bits.
royalblues Wed, 08/15/2007 - 14:43
It could be because when you use the switchport voice vlan command, the switch negotiates a specialised dot1q trunk which can carry only 2 vlans (data and voice)
Narayan
Aaron Dhiman Thu, 08/16/2007 - 07:06
Even when mode is "access"? If there is a dot1q trunk how does that differ from being a trunk port?
Here is the port status:
OIGH-CRS01#sh interfaces f1/0/9 switchport
Switchport: Enabled
Administrative Mode: static access
Operational Mode: static access
Administrative Trunking Encapsulation: negotiate
Operational Trunking Encapsulation: native
Negotiation of Trunking: Off
Access Mode VLAN: 2 (VLAN0002)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: 5 (VLAN0005)
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Paolo Bevilacqua Thu, 08/16/2007 - 07:24
Well as Narayan said, think about it as 'specialized trunk', where only untagged access vlan, and tagged voice vlan are allowed.
As a recognition to those providing answers, please rate useful posts!/
