Checking if Port is Open on 3845 router
is there a command that i can do on this router to see if a particular port is open? We have a PPP connection and just want to make sure that a particular application that we use at a remote location is able to come in thru a particular port.
But the other thing is that I assume that if it is PPP connection, that all ports are open. Am I right or am I right? Thanks for the help.
Jon Marshall Thu, 08/16/2007 - 04:37
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Do you mean a port opened that allows traffic through the router ?
If so then unless you have an access-list applied to an interface that denies certain ports by default a router will allow all traffic through so the easiest way is to do a "sh run" and under the interface statements check if there is an
"ip access-group "no/name" in or out
If there is then you need to look at the corresponding access-list so for example
interface fa0/0
ip address 192.168.5.1 255.255.255.0
ip access-group 101 in
If you found this you would then do
"sh ip access-list 101" to view the access-lists.
Jon
