3750 IOS
Aug 15th, 2007
Which version of IOS is suitable for 3750 to be used as a Layer3 switch?
med_ddevlin Wed, 08/15/2007 - 18:12
It depends on what type of routing you want to do. If you wanted to do basic routing (RIP, static) then IP Base would do. If you want to do advanced routing (OSPF, EIGRP, etc) then you would need IP Services or Advanced IP Services.
Please rate if this helps
