RME re-install
Aug 15th, 2007
Hi Joe,
we are going to uninstall and then reinstall RME due to the corruption of packages which we discussed last month.
The procedure as I see it:
- first export all the contained device credentials to a csv file.
- then uninstall RME.
- then install RME from the LMS 2.5.1 bundle and then the LMS 2.6 patch and finally any device package updates.
- Lastly import the device csv file.
How does this look?
thanks,
Marty.
Joe Clarke Wed, 08/15/2007 - 22:05
This sounds perfectly fine. Of course, by doing so, be aware that all previous history, configs, changes, etc. will be lost. You will be left with just your devices and their credentials, and will have to start over collecting all of the data.
