router serial number
Aug 15th, 2007
i want to check router serial number how can i check
ilnaiduccna Wed, 08/15/2007 - 22:00
Hi upendra,
You can execute the command to check router serial number & all see the below command.
Router#sh invertory
Router#sh hardware
upendra07 Wed, 08/15/2007 - 22:14
show inventory command is not work and i tried to show hardware it work but there is no information.I have cisco 1700 series router.
graemeporter Wed, 08/15/2007 - 23:10
Hi there,
Occasionally, the serial number is listed on "show version" - I have a 1700 series myself, but it's my home router, and I'm at work, so I can't check.
If it's not in "show version", do you have physical access to the router? If not, would you be able to contact someone who does?
Kind regards
guruprasadr Wed, 08/15/2007 - 23:16
HI Upendra,
#show inventory
-->command is applicable to specific IOS and Router Model.
#show version
#show hardware
-->might help you. Neverthless if nothing works then you need to have a Physical access to the Router.
Best Regards,
Guru Prasad R
ilnaiduccna Thu, 08/16/2007 - 01:44
hey upendra,
Router#sh hardware
Router#sh version
try these two commands otherwise go to router and "Router#show ?" it will show all compatable show commands for that particular router model
royalblues Fri, 08/17/2007 - 14:06
I prefer to have the serial number configured through SNMP for all the device that do not support the inventory command or report the processor ID when used.
snmp-server chassis-id
once you have this configured, you can fetch the serial number by uisng the sh snmp command
