ACS solution engine to Join Domain
Aug 15th, 2007
Hi Sir,
I would like to know how can I join a Cisco Secure ACS solution engine to Domain? The only way for me to access the ACS solution engine is via console. I know from the fact that in order to run PEAP with Windows AD, the ACS has to be a member server of the Domain COntroller. I plan to run PEAP MS-CHAPv2 for my wireless deployment and Windows AD as the external database and ACS solution engine as the RADIUS server.Please advise.
Thank you.
Delon
Jagdeep Gambhir Thu, 08/16/2007 - 16:02
Delon,
You need to install remote agent on the member server. Using remote agent appliance will be able to talk to AD
ACS----> Remote agent----->AD
Remote Agent,
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/4.0/installation/guide/remote_agent/rawi.html
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/4.0/user/guide/n.html#wp372828
Hope that helps !
~JG
Trending Topics - Security & Network
