problems with ATA and CCM
Answered Question
Aug 15th, 2007
Dear all,
I've been struggling a long time to get my ATA's working. first I thought the ATA wouldn't work with HP faxes, but now... I even get communication errors on Canon faxes. I want to move all the faxes from my traditional telephone central, but everytime I start to move them I get problems with te ATA's.
I've attached my gateway config. Can anyone see the problem?
the ATA's are running SCCP.
could the command mgcp modem passthrough voip codec g711alaw
solve the problem?
regards,
Gerard
Correct Answer by drolemc about 9 years 9 months ago
The ATA 186 supports fax pass-through. It detects the fax answer tone, disables silence suppression, and then renegotiates the coder/decoder (codec) to G.711 u-law or G.711 A-law. It does not support ITU T.38 standard or Cisco proprietary fax relay.
Refer to Configuring the Cisco ATA for Fax Pass-through mode for more information on how to configure the Cisco ATA
Super G3 Faxes are not supported because they use 33.6 kbps to establish the call. ATA only supports speeds up to 14.4 kbps.
Overall Rating: 5 (1 ratings)
Correct Answer
drolemc Wed, 08/22/2007 - 06:19
  • Silver, 250 points or more
gerard van rij Wed, 08/29/2007 - 23:33
solution found.
"no mgcp fax T38 inhibit" did the trick
finally I can finish this VoIP project
regards,
Gerard
