How to connect via console through patch pannel a 2600 and Catalyst
Aug 16th, 2007
Hi guys ! I'm at job and my boss has assigned me a new task. Remotely, they use a Cisco 2600 to configure a Catalyst switch. The said "connect the console port of the 2600 to the console port of the Catalyst, is that possible ? If so, what kind of cable do I have to use to make it done
? I have only 1 console cable that starts with an RJ-45 connector and finishes on another RJ-45. The rest of console cables I've got are RJ-45 to COM port. The connection should be made throug a patch pannel, because of the distance between both devices.
