08-16-2007 02:12 AM
Hi all,
I'm trying to set up the simplest possible MPLS deployment: a statically-configured MPLS hop between two routers.
Unfortunately, all the documentation seems to come in at a more complex level. Can anybody help me?
I've tried a couple of potential tunnel configurations:
interface Tunnel0
ip unnumbered GigabitEthernet0/1
tunnel destination 192.168.0.1
tunnel mode mpls traffic-eng
tunnel tsp-hop 1 192.168.0.1 lasthop
no routing dynamic
interface Tunnel1
ip unnumbered Loopback0
mpls ip
tunnel mpls traffic-eng path-option 1 explicit name pathtest
no routing dynamic
ip explicit-path name pathtest enable
next-address 192.168.0.1
But both these tunnels appear as operationally down and so I can't route on them.
Any hints would be hugely appreciated!
08-16-2007 03:13 AM
hello
did you enable 'mpls traffic-eng tunne' globally?
on each physical interface in the path?
could you post complete config?
post 'sh mpls traff tunnel' output, 'sh mpls traff topo'
etienne
08-16-2007 07:06 AM
You configuration looks all ok.
Run through the checks as below:
1) Enable your IGP for MPLS TE info propogation.
2) Enable Label Switching on the directly connected interfaces. (mpls ip in interface mode) (<--Required)
3) Enable RSVP by entering ip rsvp bandwidth XXX on each concerned interface. (<-- This is optional)
4) Enable MPLS TE on the interfaces ('mpls traffic-eng tunnels' in interface mode) <----
5) Configure the TE tunnels as below. ( This is same as what you have already configured, path option you can leave it to dynamic or specify a explict)
To summarize the config should be as below.
ip cef
interface Tunnel0
ip unnumbered loopback0
tunnel destination 2.2.2.2
tunnel mpls traffic-eng path-option 1 explicit name PATH
no clns route-cache
end
router ospf 1
router-id 1.1.1.1
log-adjacency-changes
mpls traffic-eng router-id Loopback0
mpls traffic-eng area 0
interface mediatype x/x
mpls ip
<-- Tunnel IP could be unnumbered with any other interface IP instead of loopback provided the interface is in a Up/Up state., but loopback is a bestpractise.
Here is a link as a reference for basic level of TE configuration.
http://www.cisco.com/en/US/tech/tk436/tk428/technologies_configuration_example09186a0080093fcb.shtml
HTH-Cheers,
Swaroop
08-16-2007 06:22 AM
Besides etiennes comments also make sure that the tunnel destination matches the endpoints MPLS TE router ID and your interfaces are RSVP enabled.
f.e.:
R1
interface Loopback0
ip address 192.168.0.1 255.255.255.255
interface Serial0
ip address 10.1.1.1 255.255.255.252
ip rsvp bandwidth
router ospf 10
mpls traffic-eng router-id loopback0
network 0.0.0.0 0.0.0.0 area 0
R2
interface Tunnel100
tunnel mpls traffic-eng path-option 1 dynamic
tunnel mpls traffic-eng bandwidth 1
no routing dynamic
interface Loopback0
ip address 192.168.0.2 255.255.255.255
interface Serial0
ip address 10.1.1.2 255.255.255.252
ip rsvp bandwidth
router ospf 10
Your config should look similar, if anything is missing, tunnels will not come up.
Hope this helps! Please rate all posts.
Regards, Martin
08-16-2007 07:59 AM
Hey Martin, didnt see your reply before, as i was already in the answer message window :-)
Anyways
Cheers,
Swaroop
08-16-2007 07:44 AM
Thank you all for your reponses.
I have done some further research and eventually found that I was looking at this from entirely the wrong direction. I actually needed to have discovered the "mpls static ..." commands!
All is resolve now.
Thanks once again!
