OPSF routes in VPN Concentrator
Aug 16th, 2007
I am working on VPN 3030 concentrator, n i have a situation in which i have to share the all ospf routes in my network with concentrator - what i want to know is how many routes can a VPN 3030 concentrator hold in its routing table...
ASAP reply would be quite helpful for me.
Overall Rating: 4 (1 ratings)
sbilgi Wed, 08/22/2007 - 10:50
The procedure for logging into the VPN Concentrator Manager is the same for both types of connections, cleartext HTTP and secure HTTPS. Entries are case-sensitive. With Microsoft Internet Explorer, you can select the Tab key to move from field to field; other browsers might work differently. If you make a mistake, click the Clear button and start over.
The following steps use the factory-supplied default entries. If you have changed them, use your entries.
Step 1 Click in the Login field and type admin. (Do not press Enter.)
Step 2 Click in the Password field and type admin. (The field shows *****.)
Step 3 Click the Login button.
